MMAltair Posted February 12 Posted February 12 I upgraded to EISY to OS 14.1p6 and IoX 5.9.1 and the connection to HA is broken. Has anyone else encountered this problem? It seems that HA can no longer connect to EISY. Has something changed in the TLS support or the HTTP: support? Thanks Mike Quote
Guy Lavoie Posted February 12 Posted February 12 What is the HA access to eisy configured as? if it's something like ...@eisy.local, try changing it to ...@<ip address> Quote
MMAltair Posted February 12 Author Posted February 12 27 minutes ago, Guy Lavoie said: What is the HA access to eisy configured as? if it's something like ...@eisy.local, try changing it to ...@<ip address> I've tried - http://192.168.1.83:80, https://192.168.1.83:80, & https://192.168.1.83:8443. I know the IP address is correct by checking my router. I also know the IP address changed after I did the EISY update so the router thinks it is a new device (normally my router keeps the same IP address for devices it already has seen in the past). The HA documentation says to use http://.... so perhaps it doesn't support https://.. Perhaps something changed in the EISY support of http:// ? If someone else has it working with the new release that might point me to my problem. Mike Quote
randyth Posted February 12 Posted February 12 I think it's likely that the OS update did do something to confuse/break HA's ISY integration. In Home Assistant, go to Settings->System->Logs and see if you can find any error messages related to the Universal Devices ISY/IoX integration. If you do find something, you can go here and start a New Issue to see if the author can fix it. -Randy Quote
vbPhil Posted February 12 Posted February 12 For what it's worth I'm using Polisy with Home Assistant and didn't have any issues after updating to 5.9.1. Quote
randyth Posted February 12 Posted February 12 5 minutes ago, vbPhil said: For what it's worth I'm using Polisy with Home Assistant and didn't have any issues after updating to 5.9.1. That is very good to hear. Quote
vbPhil Posted February 12 Posted February 12 There's not much to adjust in the ISY Integration configuration. Perhaps there's an issue with the TLS version in EISY? Quote
Solution vbPhil Posted February 12 Solution Posted February 12 52 minutes ago, MMAltair said: I've tried - http://192.168.1.83:80, https://192.168.1.83:80, & https://192.168.1.83:8443. My ISY Integration is using this IP address with Polisy: http://192.168.1.50:8080 1 Quote
MMAltair Posted February 12 Author Posted February 12 Problem fixed. I had to connect to port 8080 to get it to work. I suppose that should have been obvious but I found another post about migrating to Policy breaking HA integration and followed that suggestion. I deleted the ISY integration in HA and it found EISY at it's new IP address with the port 8080. When i re-added it all of the previous 'entities' remained the same except the Z-Wave entities. I had to go back and update the HA integrations for the Z-Wave entities and they work now. Thanks for the responses. Mike Quote
vbPhil Posted February 12 Posted February 12 Looking at the IoX Configuration on the Polyglot V3 web page I get the settings that IoX is using, except the IP would be different from what is shown on this page. Quote
Join the conversation
