EISY and multi-scene linking
How do you call a scene from a scene without using a program?
I currently have 2 3-way scenes where I use 1 Keypad button and a separate switch in a 3-way operation.  This already works correctly.  Now, I want to use a 3rd kepad button to trigger both of these scenes.
The application is that I have some lights over my bed.  1/2 controlled by one 3-way circuit, 1/2 by the other.  While I sometimes want these controlled separately, other times I would prefer to have a single control that would activate all the lights.
I tried to create a scene with the 3rd button, and then drag the other scene into it, but the UI didn't let me do that.
I tried to add all 5 devices (3 KPL buttons and 2 dimmer switches) to the scene, but it seemed to complain that the devices were already controllers in other scenes, so it wanted me to configure them as responders.
I tried to group the 3 KPL buttons together, and this kinda worked (meaning the 3 KPL buttons correctly linked), but the 3-way operation with the dimmer didn't work. I thought that since KPL.A worked with the scene to turn on Switch1, that if I had a new scene with KPL.A, KPL.B, and KPL.C, if KPL.C turned on KPL.A, it would also trigger the scene that KPL.A controlled
Edited by snazareth
Add more clarity
Solved by Guy Lavoie
You can't have a scene trigger another scene (though it can be done with a program and using the Virtual plugin). Instead, you should simply create a new 3rd scene, that involves all the lights that you want it to control. Individual lights can be responders to dozens of scenes if you wish.
