Program Logic Assist Pls
Am I writing this correctly? My intention is to trigger THEN if either of the /Main House/Sensors are tripped AND the $Gates_ProgON is 0. I wasn't sure if I needed the parenthesis around the separate pairs of conditions with an OR in between or not.
North Gate OPEN - [ID 0019][Parent 0031]
     'Main House / Sensors / North Gate' is switched On
    And $Gates_ProgON is 0
     Or 'Main House / Sensors / ZY 033 North_Gate' Access Control is Window/door is open
        $North_Gate_Open  = 1
        Run Program '_North Gate' (If)
I would likely write it like this just for clarity
That's the better, more predictable way of doing it.
Thanks for the insight.
Right now, Gates_ProgON can be fired with a second gate. That program has a different Then action.
Should I create individual variables for each program, or is there a way to write the statements in each program so they do not fire each other off. (The second gate program is identical, using different sensors.)
Also, can I import the updated text into EISY, or do I have to recreate it using the UI?
