Perpetual License No Longer Active
Title pretty much say it all. Getting the same error messages that were discussed 2 months ago with no actual solution to the "Error processing....due to high volume"... License not showing as purchased. You can try to throw another $30 at it but even that comes up with Error. Can't update it, can't re-install it.
So what it looks like right now is there is a separate Beta version. Am I to install this along with the current not working one which would mean loosing all my programing for the devices OR install the beta and remove the old one installed?
Edited by TRI0N
What was suppose to be a 30 minute add now running into 3 hours and had to cancel 2 client appointments. Not good.
It want's to authenticate with KASA Cloud apparently.
Username is actually the Kasa Username or email? Because you when you login to Kasa it's email NOT the username. So lets try to get clarified before I cause another account lock out for 10 minutes so I can play Guess BS Again Game.
I've not heard anyone else report the ""Error processing....due to high volume" issue.  Please enable debug mode, restart the node server and if you see that error then "download log package" and PM that to me.
Sorry you are so bothered by kasa user or email, your kasa login user is your email so use that.  Yes, for new devices it requires authentication, that's part of the issue mentioned in the first paragraph of the README "This nodeserver relies on a mostly undocumented and unofficially supported local API which of course TP-Link could break at any time, and has in the past, but luckily others figure it out."
For the beta, as mentioned in the beta thread Kasa Devices to support
Please install Kasa plugin beta trial 3.2.2 in a new slot and test.  I've only done minimal testing so let me know if you have any issues.
