Strange upgrade "Warning" prompt in Admin
My version of IoX is currently 5.9.1.  When I signed in via java on my PC this morning, I got a "Warning" prompt that suggested there are update packages available.  Clicking the release notes link brought up a web browser page that suggested that I use UDMobile to upgrade the OS to 3.9.0_9.  Couple of strange things:
First, the font on the "Warning" popup is different from the usual font in my Admin Console
Second, the "upgrade" is to a lower number
Third, there is no mention of this "upgrade" on the official UD web page
Fourth, the release notes say to use UDMobile to upgrade the OS, but the "Warning" prompt says to click the Upgrade Packages button on the Configuration tab in the Admin console.
These discrepancies make me a little nervous.  Any suggestions?
There was a recent minor update
For the eisy, you can verify your firmware versions at: eisy.local:8443/WEB/sysconfig.txt
The current UDX version is 3.9.0_9
Current ISY version version is 5.9.1_18
Edited by Techman
21 hours ago, maxnorth said:
Same behavior here, although I am on 5.8.4.
Note that the update to 5.9.1 is a MAJOR update since you're still running 5.8.4. If you run update please run from admin console and allow a lot of time for the update to run. Some reported as much as 30 minutes depending on the size of your install (number of devices and plugins). Be sure you read the release post regarding 5.9.1 update process.
Edit: Fixed link. Thanks @Steve L for pointing that out.
