March 28Mar 28 @bpwwer Installed Ambient Console nodeserver and is not reporting Feels Like, Dew Point, and Lightning Strikes per hour. This data is displyed in the AmbientWeather nodeserver Main node. Can this be added to AmbientConsole? Love not having to get my data from the API. Thank you...
March 28Mar 28 @tlightne You can set the log level to debug and check what data is coming from the console to see if it is there. However, both plug-ins use the same code to parse the incoming data and create nodes and values. The only difference is how it access the data. So if it's not showing up, it's most likely that the console is not sending it.
