SJK Posted April 4 Posted April 4 I have a handful of Hue bulbs (and some other Zigbee devices) on my eISY. Within the past week 2 of the hub bulbs stopped working. These are the fancy lightguide glass bulbs. First the one in the master bedroom pendant stopped responding, then a day or so later, the one in my daughter's bedroom pendant. I factory reset them but they will not re-add to the eISY. First I tried an update/interview, then the reset with removal from the eISY, but again, will not re-pair. The lights work with bluetooth on my phone. (They aren't dead). I set up the hue app to verify that they still function. They are only maybe 2 months old? I doubt the zigbee radio is dead- they failed nearly simultaneously. No power failures or surges etc- I use whole house surge suppression and we have relatively "clean" (stable) power here. The only interim change is upgrading to 3.9.1 and turning on Matter support. I have no matter devices, and I did try turning it back off without any luck. But this issue didn't temporally appear- I updated to 3.9.1 a week or two after it came out, and this issue started a week ago. My zigbee network is fine- other devices work, including the other hue bulbs in the house. The regular 60 and 75w A type bulbs are still doing their thing- including those in the same rooms. This isn't a range or interference issue- nothing else has changed and again, everything else just works. (Side note- have the Polisy running a separate Zigbee network on a separate channel for exterior/window devices- completely separate radio frequency, should not have any issues there- have been happily co-existing since the fall). Any thoughts? I have no idea what to troubleshoot next. Quote
Guy Lavoie Posted April 4 Posted April 4 You mention "hub bulbs" at the beginning but then mention "other zigbee devices". Are they configured as Hue devices with the Hue plugin, or as straight zigbee devices? Quote
SJK Posted April 4 Author Posted April 4 I use some Tuyo clone things for window candles- the ones that you splice into the power cord. Something like those old Sonoff Zigbee basics. Also a couple of Sonoff USB on/off switches for the Lectrofans. All of those items are working just fine as well. I use no hub or nodeserver for the hue devices- they are linked directly to the eISY using the ZMatter dongle. Same for the other devices mentioned above. Quote
Guy Lavoie Posted April 4 Posted April 4 Since you have a Polisy with a separate zigbee network handy, have you tried pairing one of these non responding bulbs on that network? As a test. Is there a factory reset that you can do on them (usually powering them on and off several times in a short period)? Quote
SJK Posted April 5 Author Posted April 5 I did factory reset them multiple times - screw/unscrew method. They were successfully reset. Turn off the bulb for 5 seconds Turn on for 8 seconds Turn off for 2 seconds Turn on for 8 seconds I have another one of these bulbs planned for another room when I install the pendant- I just tried to link it to the eISY in place of one of the nonresponding bulbs and it instantly paired, confirming it's not a radio interference issue, etc. When I use the Xray function to see the devices in the ZB network- I have 16. I only have 10 devices on this network. There's devices there I don't have and the ones that don't respond and have been removed from the eISY. None function- I get errors if I try to interact with or query them. I have removed them from the zigbee network before removing them from eISY, but they still persist in the all devices table, and if you do a synchronize new and delted with interview they come back. How do I permanently remove them from the network? Not sure this has any actual bearing on the actual problem, but seems odd I cannot remove anything ever. Quote
SJK Posted April 5 Author Posted April 5 Doing some forum searxihng about orphaned zigbee devices I found an acknowledgment in 2023 that this was a bug and would be fixed within the week, followed by a user stating still not fixed a few months later. Other threads were all closed without any replies or that upgrading firmware fixed it. Perhaps a regression? I'm starting to think that if the controller still thinks the device is there, it's not going to re-pair. But if I cannot delete it, I'm stuck. I'll put in a ticket to ask. Quote
Guy Lavoie Posted April 5 Posted April 5 Yes, sounds like a ticket is next. Let us know how it turns out. Quote
