SHM Posted Monday at 06:51 PM Posted Monday at 06:51 PM I have successfully installed the plugin on 2 separate Polisys, using 2 different Weatherbit API's (2 accounts). The data fields seem to populate OK but on 1 Polisy, I get a 429 error. Any suggestions? Quote
bpwwer Posted Monday at 07:13 PM Posted Monday at 07:13 PM I believe the 429 error is because you've exceeded the number of calls you're allowed to make (in a day, if I recall correctly). You may need to increase the polling interval. Quote
SHM Posted Monday at 09:43 PM Author Posted Monday at 09:43 PM OK. It is strange that only one policy gets the error and the Weatherbit plugins are set up on 2 separate accounts. Quote
bpwwer Posted Monday at 10:18 PM Posted Monday at 10:18 PM The error is coming from WeatherBit https://help.weatherbit.io/faq/what-happens-when-i-exceed-a-rate-limit/ Quote
SHM Posted Tuesday at 01:34 AM Author Posted Tuesday at 01:34 AM Understood, but why would one plugin have an error and the other does not (given the polling settings are the same but the API's differ)? Quote
bpwwer Posted Tuesday at 04:04 PM Posted Tuesday at 04:04 PM I don't know and I have no way to investigate that. From the information about the WeatherBit API, the number of queries made by the plug-in are the only thing that should trigger that and the polling setting is the only configuration of the plug-in that controls the number of queries it makes. Quote
SHM Posted Tuesday at 04:27 PM Author Posted Tuesday at 04:27 PM Makes sense. I have the free “hobby” subscription so any recommendations on the polling settings? Quote
SHM Posted Tuesday at 11:57 PM Author Posted Tuesday at 11:57 PM So I have the short poll set at 3700 and long poll at 43200 but still get the 429 error Quote
