I think a java update broke my launcher
My mac popped up a java update and i clicked ok.  Now when I click the launcher it shows the icon on the screen then quits right away.  does not load the launcher finder window or anything.  Anyone else experience this?
Solved by Techman
I had the same issue with the current Java update. I had to uninstall Java and re-install, that resolved the problem..
Did you still redownload the current java version or a specific build?
I installed the latest version, Version 8 Update 451 (build 1.8.0_451-b10).
did that and it still gets stuck.  redownload start.jnlp and it looks like its doing its thing but stuck at downloading application.  Even though thats there the iox launcher gets added to the desktop.  if I click that it looks like its gonna start with the UD logo on screen but just quits.  Not sure where to go from here.
I ended up updating my mac OS and rebooting then clearing java cache and redownloading the start.jnlp which seems to have fixed it. But it didnt make my iox launcher shortcut for me.
When you run the "start.jnlp" program it will install the IoX Launcher icon on your desktop. If you still don't have the icon then clear your java cache again and run the the start.jnlp program again.
@toptierweb After following @Techman's advice, I usually like to past this into a browser: http://<eisyip address>:8080/admin.jnlp, substituting the eisy IP address into the string.
This will put an admin.jnlp file on your desktop. Clicking this shortcut  will then be a direct local link right into your Eisy, skipping the whole launcher process. Only works for local connections though. Enter your local username and password.
cheers.
cheers.
This is awesome.  I was wondering if there was something like this.
that did it.  thanks
  • 4 weeks later...
cheers.
After trying everything else on this page multiple times, this is the only thing that worked.  IOX launcher seems to be permanently broken on my Windows 11 PC.  Thanks, DBWaner5!
