Error when adding Kasa
I have a mostly insteon setup with a few zwave locks.  I am trying to add a couple of Kasa light switches in an outbuilding that is on the same wifi network.  I assumed i need to go to polyglot and add the kasa node server and pay the $30.  But when I click activate free trial or purchase the license I get this error   AxiosError: Request failed with status code 404
So I guess I need to enable the ISY portal which I wasnt using so i did that and was able to et the plugin running and a node set up.  But I cant seem to add the kasa devices to it.  Are there any tutotials for this? I cant seem to find one
I have a bunch of Insteon devices runnign in EISY fine.  I added the Kasa plugin in polyglot UI and i couldnt add any of the devices.   Then I added the beta version and now it at least sees my 4 HS200 switches.   They are in ISY admin as well.  They seem to just be kasa controllers tho and Can not be turned off or on. However when I click on the folder I added them to ( which it added the whole kasa controller to not just an individual device ) It knows which are on and off and that is accurate.  I cant add them to any programs or anything like that.  What am I doing wrong?
5 minutes ago, tazman said:
From what I remember you setup you devices in the Kasa app then PG3 will bring them over to ISY.
Yea I added them in kasa App.  I updated to the beta version of the kasa plugin in PG3 thenit saw all the devices and they are in the ISY but it just says connected.  no ability to turn it on or off or anything. no info about it nothing.
Are your devices listed as being supported?
The known list of supported devices models are:
  • HS100 (US)
  • HS110 (US)
  • HS220 (US)
  • HS300 (US) SmartStrip
  • KL110 (US)
  • KL120 (US)
  • KL130 (US)
  • KL430 (US) LightStrip
If you have another device not listed and it is working properly please let me know.
Unknown devices
All other simple plug and bulb devices should work, the nodeserver attempts to figure out the capabilities of the device instead of hardcoding based on the model. But if you have an issue please add to UDI Poly Kasa Issues Feel free to Fork this repo and add support as you like and send me a pull request.
@toptierweb  Just to double check the obvious, some of the node servers load in as a "group".  The controller is the Top level. Is there an arrow to click on the left side of the controller node to expand the "group"?
If so if you click it, it will expand and show the other nodes. If this is not what you like for layout, you can right click and select Ungroup and all the sub nodes will move out to the main level. Screenshot2025-05-10at9_04_00AM.jpg.0d635c94076f4d5721d0b98a5ceab609.jpg
  • HS100 (US)
  • HS110 (US)
  • HS220 (US)
  • KL110 (US)
  • KL120 (US)
  • KL130 (US)
Unknown devices
They are HS200 which is an hs220 but just a switch not a dimmer.  They seem to be working now or at least allowing on /off and showing me status.
All of a sudden it started showing up.  Now if I can get my home assistant to expose them to homebridge that would be great but I cant seem to find which domain they are under.
      37.8k
      377.4k
