Program to set Inlinelinc dim setting?
Attempting to create a "THEN" to set the dim setting for an Inlinelinc in a program. All I see are On, Off, Faston, Fastoff, a lot of Beep Durations, Backlight levels. How do you set the particular dimming level?
I have the ISY-99i and the device is an InlineLinc dimmer, brand new, v.38.
Mitch
If you look here
http://forum.universal-devices.com/viewtopic.php?t=4784
you will see I had a problem with doing a Status on an In-LineLinc also. You problem is probably related to the same bug which should be fixed in the next release. Until then if you add your In-LineLinc manually you will see there are 2 type of In-LineLinc available.
1st [01.02] (2475D) In-LineLinc Dimmable
2nd [01.1A] (2475D) InlineLinc Dimmer
Auto select seems to use the 2nd one which didn't work for me. I you manually select the 1st one it may work better.
Thanks very much! This worked.
Mitch
If you look here
