Garage door keypad
Migrated to eisy. Working out the bugs. Latest one is my garage door sensor shows on. All of my keypads linked to garage are lit. Garage is closed. Buttons control the door but wont go off. Any ideas on how to fix with out deleting and re setting everything up?
Sent from my SM-S911U using Tapatalk
There's always a few simple things to try with Insteon that don't take that much time to try and see if they work.
In iox try right clicking on the sensor for the garage door open close (assuming an iolinc) and click Restore Device
Migrated from a ISY994i? If so, what release was it at? Followed the migration procedure with backup?
Yes followed everything. Think i found the issue. Had new garage door installed, he forgot to install the metal plate on the door
If you have remote control short distances some new ones have lights that make RF noise. Some makers sell bulbs tested to work with their openers. Since the I/OLink is power line only. If your control of the opener starts getting flaky. Putting its power plug on a Filterlinc may help or a Dual Band module in the I/OLinc's feed through outlet may also help.
