Elk Plugin for Eisy
Have been using UD devices for 12+ years. I just set up an eisy from scratch. I installed and configured the Elk plugin. All seems to be working well except that when viewing the Elk Controller module via the Admin console, the M1EXP Status, constantly connects for 5 seconds, then disconnects for 1 second, then repeats the cycle for hours.  Any idea how to resolve this?
Also when I purchased the the plugin, in my purchase history, it shows reinstall. Is this because I set up the trial first? Do I need to reinstall?
Hal
I'm not sure on this as I don't use the Elk plugin. Maybe others can help specifically. However, I recall some saying that only one wifi connection can be made at a time (or something like that).
No, at least don't think so. I just checked my "Purchases" and all installed/functioning plugins show "re-install". Any plugins that I don't currently have installed just show "Install". Should be good as you see it.
Edit: Moved to the Elk plugin area of the forums. You might look at other threads for connection issues.
These might help:
https://forum.universal-devices.com/topic/42457-elk-m1-with-eisy-and-alexa-voice-control/
https://forum.universal-devices.com/topic/43232-error- - controllertimeout-elk-controller-timeout-sending-message-sd/
https://forum.universal-devices.com/topic/42966-elk-migration-from-isy-eisy-connection-errors/
