Local Access
Is local access without cloud integration possible?  I cannot get it to work.  Thank you.
What exactly do you mean by "local access"? IoX finder is not showing your controller? If so, try clicking on "Add" and writing the URL manually. For example, if your controller appears in your router's device list as 192.168.0.123, then the URL would likely be
https:192.168.0.123:8443/desc
Sorry, no not the IoX, the Tesla Powerwall plugin.  I can only get the cloud access to work.  Thank you.
It should but i have checked it recently.  Tesla may be changing the local access requirement.  I am ravelling so i cannot check until i return as you needed to do a physical switch when starting - see the notes
