Custom Icon config
Upgraded from polisy to eisy.  Small issue with configuration custom icon colors in favorites.  Tried synchronization but no effect.
Does the Node have a Status-Value on the Home Tab?
I can replicate a similar error for Nodes which do not have Status Properties.  If there is no value (defined values) then Advanced Configurations will not work.
No, it does not have a value.  it is a rated garage door opener.  Interestingly, my other eisy (at another house) displays a value for a similar ratgdo node and I can customize it.  Should I delete the node from eisy then add back?
