Remotec BW8510US
Go to solution Solved by Techman,
I've been migrating away from homeseer and have a few 8 button remotec scene controllers.  When I add it in it shows up as a controller and an awake icon.  There doesn't seem to be a way to detect the scenes when you push one of the buttons.    I've tried redetecting it, interviewiing it, used compatibility mode etc, but I am just stuck and have run out of ideas how to get these things to work.  Has anyone used these and can offer some insight on how to get them to work.
.... ok, scratch my original answer... I saw remotelinc in the text and not Remotec BW8510US.. I'm not a zwave user so can't help.
Edited by paulbates
I'm using the Eisy  5.91.   I just got this about a week ago and have almost everything working perfectly except those 2 remotes.  They are kinda important to me to automate my fish tank stuff when I need to turn pumps and lights oon and off while I clean it.
Yes I am using the usb board that UD recommended.   Everything is working fine so far.  The 2 kwikset 916 locks took some work but I finally got through that.
It only creates those 2 items at the bottom left.   So all I can select in the events is like a battery query or a device responding.   It should allow me to pick any of the 8 buttons dependiing on how I push the buttons but those options just don't show up.   I have 2 of these and they both do the same thing.  I've tried reinterviewing and switching compatibility mode.
I noticed you have pending writes to ZY107 and ZY105. Are those your BW8510US?  If so, put them into the linking mode, one at a time, and right click on the device and click on write updates.
Being that Zwave devices are designed to work with various controllers, the names on its node may not reflect its actual purpose. You might also end up with nodes that you don't need in which case you can create a folder and move them into the folder in order to clean up your device tree.
Edited by Techman
Those are different devices,  Not sure why they haven't finished with writing.  I like that idea of moving the other stuff out of the main into another folder.  It is way to crowded and hard to find stuff.  I'm gonna keep plugging away on this, sooner or later I'll get these things working or find a different keypad option.
Can you post a screenshot of the ZY110 Controller window.
It's  remote possibility that those pending writes might be causing an issue. You should get that cleaned up.
If you're still then having issues with  BW8510US I would then exclude it, do a factory reset on it then do an include.
Also, don't forget to do a Zwave backup any time you make changes to your Zwave devices as Zwave is NOT included in the regular eisy backup
There's almost nothing on the screen to really interact with.  From my understanding this can be a controller and you can link other devices to it, or at least that's how I read the instructions but in homeseer I could always detect a button press or a hold down or a fast on etc.  and was able to set an interaction based on that.   I bought these a really long time ago but there is no support for them that I'm aware of.    I do have a switch close to my tank and I'm thinking about putting a zooz zen32 switch in its place.  That will at least allow me to get some special buttons back to use with my tank.     I'm surprised no one has a good keypad only option for Zwave either AC power or a handheld like this one.   Eaton made one and I had a few of those but there was always something lacking with them and I had a hard time to get them to work reliably.
Thanks for that reminder on the backing up of Zwave devices,  homeseer also had that same issue that you had to back up the zwave stuff separately and I got burned on a restore once and had to start from scratch.   When doing a backup maybe they should have a popup to warn you to also back that up and have it included in the zip you download so you have the most current information for the restore.  It was a real let down that the backup wasn't all there.  It's  literally an entire day pissed away having to relearn the devices and then fix the events/programs.
@PalChgo
You should first address the pending writes on ZY 101, ZY 102, and ZY 111 as it's possible that they may be adversely effecting your Zwave network.  You may have a weak Zwave mesh network and need a range extender to improve it.
The Smarthouse is having a sale on Zooz products through July 8th. They have an excellent  zwave range extender/amplifier.
https://www.thesmartesthouse.com/
The  BW8510US (aka ZRC-90US) is Zwave certified so it should be compatible with the eisy.
Herer's the link to its certification and additional info:
https://products.z-wavealliance.org/products/1526?selectedFrequencyId=2
Thanks for the info.  My only guess is perhaps eisy is not picking up or interpreting something in the interview to create the items it needs.  A may need UD's help on that as I know it works with other platforms.   When adding those keypads I went as far as laying the device on top of the eisy ;)
All those other devices devices are battery only devices.  I've queued them up to update but it hasn't occurred yet.  I can't say I've had any real delays on stuff happening but I do want it to run smooth so I'll look at the sale, there might be something else I want ;)
Have you tried doing a factory reset on them before adding them to the eisy
Re: your battery devices with pending writes, manually put them into the linking mode and them click on wrtie updates. You should only have one device in the linking mode at any one time to avoid their link tables becoming cross linked.
Being that your zwave network is functioning I doubt that UD Support can help.
I have all devices cleaned up and responding as expected.  I tried factory resetting and then linked them again but each time it's the same issue, but what's odd to me is both of them exhibit the exact same issue.  But if I use a different hub (HS4) it does work as expected so could there be some sort of bug in eisy?  Overall I am quite happy with the device,  I used to have an isy994 many years ago so I am familiar with how it works.   I did buy a few zooz dimmer keypads and the repeater so just waiting for that stuff to get here so I can swap a few older ones out that are switch only devices.
If you did a factory reset before you tried to include them into the eisy then there's not much else I can suggest. Being that both your devices and the eisy are zwave certified there's no reason why they shouldn't work.
Do you have the instruction manual for the devices?
Are their batteries new
Yeah I did put in new batteries and even went so far as to be a few feet from the eisy when I tried the linking.  It's really strange that I can't get these items to link.  I've turned on compatibility mode, security mode off, basically anything I could find in the eisy setup that maybe might make a difference.   The only thing that makes these different than maybe some other devices is that they can be used as a controller, but going through the instructions I don't see any special instructions for linking when it's not used as a controller.  I haven't given up just yet ;)  It could be something really simply stupid but it's escaping me what that is.  I may reach out to support and see if they have any ideas, it certainly couldn't hurt.
