Recent eisy migration from ISY994-Scenes messed up.
I recently migrated to eisyfrom ISY994.
When I migrated my 994 to an eisy, I did a backup on the 994, and loaded that into the eisy (as per the instructions).  Unfortunately, the scenes got messed up.  I have attached a screenshot from the 994 and the migrated eisy scene.  Same scene.  What is going on with the migration?
I should note that the PLM that is on the 994 has NOT moved.  I don't want my Insteon scenes to be messed up and I still have to convert the programs that use the old Elk module to the new Elk plugin.
Everything looks normal.  They may display differently in the eisy. Are your scenes working properly?
The scenes may not update until you either turn them on or off
I noticed you have pending writes on some of your devices. Right click  on those devices and click on write updates
Be sure to do an eisy backup
The PLM isnt attached to the EISY to update anything.
