July 21Jul 21 I did the following: Take a backup of your IoX (Admin Console | File | Backup IoX) Take a backup of your plugins (PG3x Dashboard | System | Backup/Restore) Upgrade Packages (the Admin Console | Configuration tab | Upgrade Packages button) After the system came back, I tried to login to the admin console with "admin/admin" and it gave me a "[LIB_ERRORS-403]" error. I then tried to ssh into the command line and that still works. It also still works from the iOS application. The PG3 webpage works as well. Is there any way to reset things so that I can get back into the admin console?
July 21Jul 21 Solution Open your admin console and click on the add button. Create a new entry https:// (your eisy ip address):8443/desc Going forward you'll need to access the eisy using this entry. This is due to a recent change in the UI Using admin console - Can't connect/LIB_ERRORS-403 - eisy - Universal Devices Forum Edited July 21Jul 21 by Techman
July 21Jul 21 Author Thanks, that got me in. How do I remove the old,broken link (or should I)? The "Delete" button seems to be greyed out. The post you linked to says that port 8443 will go away at some point.
July 21Jul 21 For now the old link can't be removed UD is in the process moving away from a java based UI to eisy-ui eisy-ui Alpha release - Feedback - eisy - Universal Devices Forum
July 21Jul 21 3 hours ago, TomJ said: Thanks, that got me in. How do I remove the old,broken link (or should I)? The "Delete" button seems to be greyed out. The post you linked to says that port 8443 will go away at some point. FYI the login box of AC will be more obvious with regards to which creds to use.
