August 2Aug 2 Anyone willing to take a look at the code on this repo https://github.com/UniversalDevicesInc-PG3/udi-shelly-poly/tree/master and mod it to to support the latest Shelly device, Shelly Plus RGBW PM ? The current repo supports the RGBW2 but it was recently retired and its newer chip version is Shelly Plus RGBW PM which greatly improves performance esp with dimming and speed to dim. https://github.com/UniversalDevicesInc-PG3/udi-shelly-poly Edited August 2Aug 2 by tomas21
August 7Aug 7 I started on a MQTT version of the plugin that would require every Shelly device to be configured to connect to the eISY MQTT broker. But you can sort of already do that with the MQTT plugin. So was going to try something more native so you could discover and use installed Shelly devices “out-of-the-box,” but never really made much progress. The Shelly devices I have installed here actually have Tasmota flashed on them. Perhaps I can complete the MQTT version and roll it out and followup with a version 2 for more native support. The capabilities and node definitions would basically be the same - just more plugin-specific configuration of each Shelly device needed for the MQTT version.
August 12Aug 12 Never mind. The information originally posted was for Gen 1.0 devices, which won't be supported. Edited August 12Aug 12 by Goose66
