Portal disconnected a couple of nights ago
This portal disconnect is unusual, typically it's rock solid. I was notified of the disconnect via UD Mobile. I never received a Portal reconnect.
A couple of things I noticed:
- Finder for https://eisy.local/desc doesn't work anymore. No popup for LAN, Cloud, PG3 when selected. Authentication to Portal from the AC doesn't work anymore, although local admin does. I am a alpha/beta tester of the new EISY web interface. And of course, I did try the usual Java clear cache etc with no effect.
- And while trying to figure out what was happening with Portal I noticed this in the AC as well👇
Not the end of the world, but I'm curious to know if anyone else noticing this behavior?
Maybe it's just me??
I located your uuid based on your email address and checked the logs.
I see that it's currently online, but there had been an issue (and maybe still there) where there were more than one instance of eisy-ui running. That stems from a bug in an alpha release.
A reboot should solve it.
Alternatively, you can do this:
  1. Stop the service: sudo service eisyui stop
  2. Check if you have any eisyui process running, and if so, kill it. You may have it if you installed 0.5.5.
    1. Run this: ps aux | grep eisyui
    2. Check if you have any process running as eisyui.
    3. If so:
      • Take note of the process id (pid)
      • Run this: sudo kill <pid>
  3. Restart the service: sudo service eisyui start
@bmercier really? After a more than a decade and a half of ISY/Polisy/Eisy usage I'm pretty sure it was working. I only ever used 8080. In any event I can just go directly to Portal and check connectivity.
The other issue is login with portal credentials doesn't work anymore but it is Beta so no worry.  Local login still works.
And Finder using https://eisy.local/desc doesn't work anymore - no popup for LAN, Cloud, PG3 when selected. Other login methods that include the IP work locally.
Yes. I understand it was working before. The difference is that you now have eisy-ui installed.
Explanation:
When eisy-ui is installed, it takes care of the connectivity to portal. IoX no longer does.
eisy-ui also takes care of the "portal approval" as it is tied to the portal connectivity. The approval process involves an exchange of tokens with portal through the proxy connection which IoX can no longer do.
So, when you are using AC and connect to IoX directly (8080 or 8443), the Portal tab won't work. If you use AC and connect to eisy-ui (no port specified), then the Portal tab will work just like before. Note that you can also manage the portal approval using eisy-ui's web interface.
That is not normal. Can you try the URL in a browser? That should give you an xml doc. You may have to accept the self-signed certificate.
You should also be able to navigate to https://eisy.local
Thanks for the good explanation @bmercier
The url works fine. This is what I see the in the Finder - looks incomplete.
Edited by mmb
The line showing https://eisy.local/desc should show the type and version. The fact that it does not tells me there is a problem. Can you try the url in a browser? Does it respond at all?
Could you also try https://192.168.0.106/desc in admin console and browser? It it works, but https://eisy.local/desc does not, it could be explained by a dns resolution problem.
On 8/15/2025 at 11:13 AM, mmb said:
Hi @bmercier I don't think https://eisy.local/desc ever worked but https://eisy.local/ works fine.
I assumed it was the difference between the AC target and the web UI target.
The web ui responds on the root. /desc should return you the the same as :8443/desc
Can you please update eisy-ui, based on the logs, I can tell you are using a previous version of eisy-ui.
sudo pkg install eisyui
You may have to restart it: sudo service eisyui restart
Good morning @bmercier unfortunately same result - Not Found.
Only one eisyui running.
Let me know if you want me to check anything else.
Edited by mmb
1 hour ago, bmercier said:
What's the result of http://eisy.local/desc
If you see a web page, and not XML data, please use Chrome, and us Shift + Click reload button. This will reload the page without using the cache.
The only recent change was the Update Packages performed on Monday Aug 18, as you recommended.
Another data point, my eisy is relatively new, received in July.
This looks good now.
So entering this url in the IoX finder should work.
Thanks, should the web ui ever respond properly to /desc or is this reserved for the finder?
4 hours ago, bmercier said:
That should return an xml like in the screenshot. Finder uses that info.
Got it, all good thanks!
