Only Every Other Button Press Working using Flirc.
Not sure what gives here.  I have the flirc installed and loaded in the default ISY 40 commands found in this thread.  They showed up as I pressed the buttons.  But it only works on every other time I hit the button.
I tried deleting the whole thing and started over teaching the flirc manually the 40 commands.  Same story.  I confirmed every other button press by watching the "pressed" vs "idle" reported in the admin console as well as creating a program that runs on the button press.
It is like it is a toggle or something, but there is no option to make these things a toggle.  I tested it with a bunch of the buttons.  I am using my Harmony remote, the same remote that worked flawlessly with 994ir.
EDIT: I think I found the answer here in the forum.  I'll need to play with this, not sure how to get the same button to respond to two different commands in flirc.
Edited by apostolakisl
I went through and manually added every one of the 40 buttons twice.  Mostly this works.  However, 3 pairs of buttons appear to share codes at least as far as flirc is concerned.  This was not the case when 994i was receiving the signals using the same Harmony remote.  I installed the ISY codes on that Harmony from the Harmony library which had the ISY codes in it already (did this like a decade ago).  I deleted and readded these buttons several times without any success in fixing the issue.
Matching ISY IR codes according to flirc are
10/13
11/14
12/16
Have you exchanged power supply?
If you have Insteon PLM, can you try unplugging it and redoing the test?
If not, we can look at threshold values and take it from there.
I believe I have this solved.  I put all 40 codes on the flirc (both codes for each button).  ISY Codes 1-26 are Flirc keys A-Z, then 28-37 ISY codes are flirc keys 0-9, then 38-40 ISY codes are flirc keys F1-F3.  I attached the flirc config file.  Not sure if matters, but you might need to be in  keyboard mode in flirc when you import it.  They were obviously created in keyboard mode.
ISY40CodesHarmony.fcfg
