Virtual Switches as Controller in a scene?
Hi, @sjenkins thank you so much for the work that's gone into this plugin.
Any possibility to enhance it so that virtual switches can be a scene controller rather than only a responder?
Taking it a step further, also be able to create a virtual dimmer?
It would solve a very fundamental and fatal issue with the way IoX considers a scene state.
Edited by Diesel
from polyinterface import Node, LOGGER
class VirtualSwitch(Node):
    Virtual Switch Node for PG3x that can act as a controller for a native Insteon scene.
    id = 'virtual_switch'
    def __init__(self, polyglot, primary, address, name, scene_id=None):
        super().__init__(polyglot, primary, address, name)
        self.scene_id = scene_id  # Optional: Native Insteon scene this switch controls
        self.add_driver('ST', 0)  # State driver: 0=off, 1=on
    def start(self):
        LOGGER.info(f"Starting Virtual Switch '{self.name}' with scene_id={self.scene_id}")
        # Register command handlers
        self.poly.on('ON', self.on_command)
        self.poly.on('OFF', self.off_command)
    def on_command(self, command=None):
        """Handle ON command from PG3x or scene activation"""
        if self.scene_id:
            self.send_scene_command('ON')
        self.set_driver('ST', 1)  # Update switch state
    def off_command(self, command=None):
        """Handle OFF command"""
        if self.scene_id:
            self.send_scene_command('OFF')
        self.set_driver('ST', 0)
    def send_scene_command(self, cmd):
        Sends the ON/OFF command to the linked Insteon scene via IoX.
        Replace the below with actual PG3x API call to trigger a scene.
        try:
            LOGGER.info(f"Sending command '{cmd}' to scene {self.scene_id}")
            # Example pseudo-call; replace with actual API method
            # self.poly.iot.send_scene_command(self.scene_id, cmd)
        except Exception as e:
            LOGGER.error(f"Failed to send command to scene {self.scene_id}: {e}")
    def set_scene_id(self, scene_id):
        """Optional helper to dynamically update the controlled scene"""
        LOGGER.info(f"Virtual Switch '{self.name}' now controls scene {scene_id}")
@Diesel ,
sorry for the slow return, been a busy summer.
Although the programming doesn't quite work as you have above, this is a feature which should have been added long ago.  Not really sure why, I guess we all got used to using it the way we did, as a responder in a scene.
Anyway, I have put it up in beta on the non-production store in v3.1.14
I will give people a while to play with it to make sure there are not any unintended consequences.
@sjenkins
There's some really great integrations in the store, but Virtual is one of the most important.
Virtual switches/dimmers as scene controller & responder solves so many issues.
 Thanks so much for taking the time to make this happen! 😊
