Lights on at sunset or a specific time
Had started this topic earlier, but stopped due to a software glitch.  That glitch has been fixed, but the topic has been closed out.
Before closing out, I had received certain programming suggestions, but I was not able to make any work for me.
I'm looking to have lights turn on at the earlier of sunset or 6pm, whichever comes sooner, and turn off at 10pm (or so).
Solved by paulbates
Here is the "On" program
        Time is Sunset
     Or Time is  6:00:00PM
        Set 'Lighting Premise / Premise Lights' On
Here is the off program, I use something simila
        Time is  9:50:00PM
        Wait  13 minutes  (Random)
        Set 'Lighting Premise / Premise Lights' Off
This one will start running at 9:50pm, and wait a random amount of time for up to 13 minutes and then shut the lights off. You can tweak that however you want.
If you're interested, I can dig out the link to a post where I put lamp post light sensor in a project box with an insteon on/off micro module. It's Velcro'd inside on a window facing out and "switches on" around dusk.. this solves the problem of it being cloudy and dark sooner than dusk.
You can do it one program if you like.
interupt - [ID 017E][Parent 0093]
        From    Sunset
        To      10:00:00PM (same day)
     Or From     6:00:00PM
        // what you want to happen at either sunset and 6pm
        // what you want to happen at 10pm.
This program triggers at 3 different times.  6pm, sunset, and 10pm.  At 6pm and at sunset it will run true, and at 10pm it will run false.  If it is externally triggered it will be true when the time is between sunset and 10pm as well as 6pm and 10pm, so if only one of those is true, the whole thing will be true.
The fact that the program runs true twice per day would typically not matter.  If sunset is after 6pm, then the lights will be on already when it runs true the second time at sunset and nothing will change.  The on command will be sent out, but presumably they will already be on, so nothing ends up happening.  It will matter if whatever the program is doing in the then clause is an event that does not hold the same state until the second trigger.  It would almost certainly not apply to lights, but perhaps if you want it to sound a horn once per day at either sunset or 6pm, whichever is first, then it will end up sounding a horn twice, once at each time.
All,
Ty!  I will try the simple ones first.  I do, however, like the cloudy program idea.
Please stay tuned.
Edited by haroldunger
Original answer was incomplete.
Thanks to all.  The program with the combined on/off works fine.  If available, I would love to see the "cloudy" program, too.
This is an Insteon dusk/dawn sensor I built. It senses dusk and a iox program responds. You need to buy an Insteon on/off micromodule and a dusk sensor for a lamp post. The parts list is in the post.  It's not really that hard or technical
You can keep it as simple as one program.
Over time my program(s) got more involved to account for edge conditions like a dark storm cloud blowing in during the day, car headlights or other lights shining on it.
I ended up buying a project box for it and placing it in a bedroom window facing south outside.
It does work well. If it you decide to do it I can post the programs
Edited by paulbates
You can use wireless tags that have the lux feature on them for this too.  If you already are set up to use wireless tags, this is super easy to add on.  I use the USB version and plug it in to an outside outlet that is under a patio roof to keep the rain off of it.  I like the USB plugin version since there is no battery to go dead.
Edited by apostolakisl
Thank you to all for your help, but this seems above my paygrade.
I'm going to stick with the simple dusk or +/- 6pm turn on.
