Network Error
I've noticed my Alexa stopped working and when I've check portal - it's disconnected.
UI itself says "Error: Network Error".
I could live with UI issues but losing Alexa functionality is very annoying.
Tried restarting isy service but that did not fix it.
Everything else seems to be working fine - AC, Polyglot.
Anything I should try and/or check before I reboot eisy?
Are you using eisy-ui?
If so, and if the eisyui service is stopped, that may explain it.
To see if you have it installed and started:
sudo service eisyui status
To start it if you have it and it is stopped:
sudo service eisyui start
It show as running:
eisyui is running as pid 6276.
I've tried restart. Luckily fixed Portal connection but UI itself still shows same error.
It was working when I've originally installed it.
1 hour ago, firstone said:
It show as running:
Regarding the disconnection, you should upgrade eisy-ui.
sudo pkg install eisyui
Regarding the UI... what is the error?
Upgraded and restarted. Still same error:
Please open a ticket, and I will do a remote session with you.
Something's not right. The Network Error suggests that the UI is not able to contact the eisyui service, but you say it's started, so I don't get it.
Apologies for not reporting this earlier (been away), but I get a "Network Error" when I use Safari (version 26) to log into eisy-ui, but for some reason, it works with Firefox (version 142).  This occurred with the previous Safari version as well.
My version of eisy-ui is 0.6.0, but this happened on 0.5.9.
This is on an iMac running the latest Tahoe beta, but it also happened on the last Sequoia release.
The DuckDuckGo browser reports a TLS error that prevents the page from loading.
