firstone Posted Thursday at 02:35 PM Posted Thursday at 02:35 PM I've noticed my Alexa stopped working and when I've check portal - it's disconnected. UI itself says "Error: Network Error". I could live with UI issues but losing Alexa functionality is very annoying. Tried restarting isy service but that did not fix it. Everything else seems to be working fine - AC, Polyglot. Anything I should try and/or check before I reboot eisy? Quote
bmercier Posted Thursday at 02:38 PM Posted Thursday at 02:38 PM Just now, firstone said: I've noticed my Alexa stopped working and when I've check portal - it's disconnected. UI itself says "Error: Network Error". I could live with UI issues but losing Alexa functionality is very annoying. Tried restarting isy service but that did not fix it. Everything else seems to be working fine - AC, Polyglot. Anything I should try and/or check before I reboot eisy? Are you using eisy-ui? If so, and if the eisyui service is stopped, that may explain it. To see if you have it installed and started: sudo service eisyui status To start it if you have it and it is stopped: sudo service eisyui start Quote
firstone Posted Thursday at 02:48 PM Author Posted Thursday at 02:48 PM 7 minutes ago, bmercier said: Are you using eisy-ui? If so, and if the eisyui service is stopped, that may explain it. To see if you have it installed and started: sudo service eisyui status To start it if you have it and it is stopped: sudo service eisyui start It show as running: eisyui is running as pid 6276. I've tried restart. Luckily fixed Portal connection but UI itself still shows same error. It was working when I've originally installed it. Quote
bmercier Posted Thursday at 04:05 PM Posted Thursday at 04:05 PM 1 hour ago, firstone said: It show as running: eisyui is running as pid 6276. I've tried restart. Luckily fixed Portal connection but UI itself still shows same error. It was working when I've originally installed it. Regarding the disconnection, you should upgrade eisy-ui. sudo pkg install eisyui Regarding the UI... what is the error? Quote
firstone Posted Friday at 02:51 PM Author Posted Friday at 02:51 PM 22 hours ago, bmercier said: Regarding the UI... what is the error? Upgraded and restarted. Still same error: Quote
bmercier Posted Monday at 12:25 PM Posted Monday at 12:25 PM On 8/22/2025 at 11:51 AM, firstone said: Upgraded and restarted. Still same error: Please open a ticket, and I will do a remote session with you. Something's not right. The Network Error suggests that the UI is not able to contact the eisyui service, but you say it's started, so I don't get it. Quote
