Node/Device Status Not Updating Reliably In UDM
I am experiencing problems where some devices’ status indicators are not updating as expected in UDM while others do. I have UDM installed on both my iPhone and iPad and experience the problem on both devices. If I click into the node/device and then come back out the status will then be correct. See screen shot examples attached.
In the Admin condole status updates work correctly 100% of the time and are immediate. I use the USB version of the Insteon power line modem (PLM).
IOX (eisy) firmware: 5.9.1
UDM version: 1.2.15
Any help appreciated.
IMG_1272.thumb.jpeg.5f190739953e41acaef67d26d5b08162.jpegIMG_1273.thumb.jpeg.402fca64482b79bd17d306f9f8e69edf.jpegIMG_1274.thumb.jpeg.734f37cf2a5e4846ee41436066d46016.jpegIMG_1275.thumb.jpeg.5bec0598b3d3ac839be9ffe53bad639f.jpegIMG_1276.thumb.jpeg.b95d32f23d5243c0746f8e5507eb0ebe.jpegIMG_1277.thumb.jpeg.2f04c85337b4af251dca57ade554a619.jpeg
Edited by hawk4974
4 hours ago, Techman said:
In UD Mobile try doing a Synchronize
Thanks @Techman. I’ve tried synchronization but it doesn’t change my issue. I still have misc devices that show no status indicator. I think status updates/indicators should be instantaneous in UDM (if I’ve understood correctly). Perhaps I have an incorrect setting somewhere but I sure can’t figure out what it would be.
Please open a ticket and include your UUID and firmware version.
Also test when enabling only using the Local Connection in Controller Settings > Local Connection Settings. Be sure to press the test button to be sure the credentials/ip/etc are correct. Does this have the same issue? This test will help us determine if the issue is isolated to remote connection.
Thanks @Javi. I’ll get the ticket opened up.
I tested only using “local connection” and I have the same problem regardless of whether I’m using local connection or using portal connection.
