Posted September 3Sep 3 I just tried out the new TeslaEVStream nodeserver and I get all of the nodes but they are all devoid of data. any suggestions?
September 3Sep 3 Solution Can you enable debug restart node and send me link My guess is you did not go through the authenticate process (press the authenticate button) Also - did you preform the test to ensure webhook is working
September 4Sep 4 Author well, I tried re-authenticating it. then I checked the webhook and now, it is working! I'm not sure what changed but, Thank you!!
September 12Sep 12 Author I updated to the newest version (0.2.10) and it is still not working, again. I tried re-authenticating it and that hasn't helped either. any suggestions?
October 13Oct 13 Author I kind of gave up. I'm selling my tesla in a couple of months. if you would like my help, then I'm happy to get back into trying to fix this (mostly because it may help you and other people). but if I'm the only one with this problem then I'll give up. FYI: I did try installing the nodeserver in a different slot and went through the process and it still didn't work.
October 16Oct 16 Sorry to hear that is still not working - there is something in your setup (most likely the tesla APP) that is causing this. As you are selling your car, I will not spend more time on this unless others are having similar issues
