Using Z-wave as a scene controller
For those of you who use Z-wave, has anyone found a solution where the Z-wave device will control a scene?  I can only get it to work as a responder.  There is a setting under the Z-wave main menu called "Detect Button Presses" that is defaulted to "Off".  Setting it to "On" displays a worrying warning box, so I hit cancel.  The Help Wiki has no specific info on the setting that I could find.
Is there more substantial Eisy/Z-wave documentation anywhere?  Or is anyone aware of a solution to the problem?
That has been my experience, as well.  I have not gotten this to work, nor in distinguishing "control" vs "status" conditions of zwave devices in programs.  At this point, I have decided not to use zwave devices in this role.
I currently use a program or programs to activate a scene.  But occasionally, in my more complex scenes that also have multiple zwave devices as responders, I end up in what I can only describe as a feedback loop where the scene turns off and on repeatedly. That is why I am trying to find a less complex solution.
To avoid the loop, you could use a state variable as a timer, to disable the scene command trigger for a few seconds after having just sent one. But this only works correctly if you can detect the reception of the actual command (control), not a status change. Something like this:
If zwave_control Turns ON
And Variable_Timer = 0
    Then set scene...
    Then Variable_Timer = 1
If Variable_Timer > 0
     Then Variable_Timer +1
If Variable_Timer =5
     Then Variable_Timer = 0
