iTach IR - Extending to other Global Cache products
Looking to see if there has been any movement on this topic.   There was a discussion on extending the NS to support the GC 100 which has multiple modules.  NS would need a module selection in addition to the existing Connector selection.   Even allowing a pass through of the module defined in the NS configuration would work.  Any thoughts   Thank you
Nothing to report, time constraints on my side.  I don't work with Python or Node Server Development frequently so would likely need a few days to figure it out.
With that said, it is open source so it can be modified/copied by anyone willing.
Happy to take a crack at it.  Is there a procedure manual you can point be to for copying and existing project and creating a test project?
thanks
