3-Way - Insteon on-level based on time of day
I am a long time ISY / Insteon user that just moved to a new house.  In this house the lights in the master bedroom are controlled by light switches in a 3-way configuration.  I have replaced the two light switches with Insteon Switchlinc Dimmers and created the IoX scene to make them work in a 3-way configuration.
The on-level of both Switchlincs have been set to 30%.  The scene to create the virtual 3-way is also set to turn on the Switchlinc with the load to 30%.  I would like to have the lights turn on to 100% during the day and 30% at night.  As these are Switchlincs, I realize I can double tap the top of either switch and the load will turn on to 100%, but want to make it do this programatically.
I have created the program below to change the on-level based on the time of day.
        From     8:00:00AM
        To       9:00:00PM (same day)
        Set 'Master Bath Sink Lts - Load' On Level 100%
        Set 'Master Bath Sink Lts - Ctl' On Level 100%
        Set 'Master Bath Sink Lts - Load' On Level 30%
        Set 'Master Bath Sink Lts - Ctl' On Level 30%
Operating the Switchlinc with the load ("Master Bath Sink Lts - Load" works as expected.  The on-level changes based on the time of day.
Operating the other Switchlinc continues to only turns on the load to 30%, because this how the scene was created.
My question is whether anyone has an good way to have the other Switchlinc turn on the load to 100% during the day.  I have created the program below as a hack, but it is awkward as the light first comes on at 30% and then jumps up to 100% a second later (as expected).
        'Master Bath Sink Lts Ctl' is switched On
    And From     8:00:00AM
        Set 'Master Bath Sink Lts - Load' On 100%
Best I can tell, there is no way to programmatically change a scene, nor is there anything in the REST API that can be used to change a scene.
Anyone have a better solution?
Solved by kclenden
You are adjusting the on-level for each device when it is locally controlled (i.e. when you press the SwitchLinc button).  What you want to do is modify the on-level for the device when it is activated by a scene controller.
So, in the example above, the on-level for "GR-Built-In Accent #1" would be set to 30% when the scene is activated by the controller "HW-Keypad-Button A".
In your case, you would want "Set" to be "Master Bath Sink Lts - Load" and the "Controller" to be "Master Bath Sink Lts - Ctl".
Edited by kclenden
