OS 14.3/IoX 6 Release Is Now Available!
Hello everyone,
I am happy to announce the availability of OS14.3 and IoX 6. This is a major release which upgrades your OS to 14.3.
WARNING:
Instructions:
  • Backup your Z-Wave if any (Z-Wave | Backup)
  • Backup your IoX (File | Backup IoX)
  • Backup your PG3
  • Click on Upgrade Packages in Admin Console | Configuration tab. Do NOT use ssh as it will brick your system.
Enhancements:
  • eisyui is now the default interface
  • HomeKit support is now installed by default
  • Better WiFi and Bluetooth support
  • Dynamic profiles for better plugin support
  • Node property history is now on by default
Fixes:
  • mqtt disconnects causes plugins to stop working
  • misc fixes for plugin support
Recovery options for eisy:
Almost all issues related to this upgrade seem to be related to an interrupted upgrade especially when using UD Mobile or when eisy is on WiFi. If your eisy does not come back online after 2 hours, please do this:
  • Press/hold the power button -> red.
  • Attach an HDMI monitor and USB keyboard to eisy, then click the power button -> blue.
  • Watch the monitor. If you do not get a login prompt, please submit a ticket, with a picture of the screen. Otherwise
  • Login using admin as login and admin as password
  • Issue the following commands. If prompted for password, type admin
sudo rm /var/udx/.udx_install_cleanup
sudo rm /var/udx/.upgrade_status
sudo pkg install -f isy
sudo service udx restart
  • Wait for two minutes
sudo service isy status
  • If it does not show running, then submit a ticket with a picture of the screen. Otherwise
  • Your eisy should now be available in your IoX Launcher. If it is, launch the Admin Console, go to the Configuration tab and click on Upgrade Packages button again. Wait till completion or reboot.
  • If eisy is still not available in your IoX Launcher, then:
sudo dhclient re0
Included in the original post.
Home Assistant not starting up after upgrade:
In order to support IPv6, /etc/rc.conf will be rewritten. If you had Home Assistant running, you might need to add the following lines in /etc/rc.conf:
vm_list="homeassistant"
vm_enable="YES"
vm_dir="zfs:zudi/vms"
If this still does not work, try:
vm_dir="zfs:storage/vms"
In short, you need to use the zfs pool name that you used during setup.
eisy-ui with no status / Subscription not working
