Order of KPL buttons in My Lighting
Once I renamed all my buttons on 8 button KPL, how do I tell which one relates to which button (physically). In a new KPL I installed, the first one is the load, but the others are not sorted properly. Is there a way to see the underlying address? Is there a way to have them sorted properly?
For what it is worth, if I look under 'Buttons Grouping', there is a different order, but that is wrong also.
I am thinking about removing the KPL again and re-linking and then rebuilding everything, but I am wondering if I will see the same thing again and only have wasted more time.
Any ideas.
When I renamed KPL buttons they still appeared in button order even though that was not the collating sequence by button name. Regardless of that click on Rename and look at the second line in the Rename popup labeled Address. It retains the button number as the last digit on mine. Just cancel the Rename popup.
Thanks for the pointer. This worked well to let me know what each was. Maybe one of the guys from UDI knows how to sort them... or why they get out of order. I have never seen this before (that I noticed).
