V6 Login .. is Portal login it for admin console?
So is it no longer possible to set your own user / password for the local admin console ?
I just seems bothersome for accessing your programs and such to require you portal login....
Solved by Guy Lavoie
Yes, you can still do so. You can choose to work either way. If you look at the URL entries in IoX finder, you will see whether a port number is defined or not. It always used to be "https://<ip address>:8443/desc" and if you use that, it will ask you your usual admin login and password. If you have an entry without a port number, such as "https://<ip address>/desc", then that will bring you to the login screen where it asks you for your portal login and password.
So if you have an entry without a port number and you'd like to login with your IoX admin name and password instead, create a new URL entry in IoX finder using the Add button.
