New ZWave Device Update?
Has anyone encountered this behavior with adding a new ZWave device?
Recently, I purchased a ZWave On/Off Module with Energy Monitoring capabilities. I enrolled the device as I have done with other, older ZWave modules. The process went without a hitch.
After a few minutes, I noticed that the device entries all had the green <Writing> status next to each entry.
For Insteon devices, there is an explicit command for finish writing updates to a device.
What are you supposed to do for ZWave devices? I have tried leaving the device alone and waiting for the <Writing> status to go away. When it didn't go away, I tried putting the plugin device into pairing mode. No change.
Does anyone know what's supposed to happen here? Or is this device just something to return for another device from a different company? Thanks.
Is the new ZWave device physically distant from your other ones? If so, try moving it closer and try adding it again.
Just to be clear, the entities for the module were created and everything looked like it completed. But after a few minutes, the <Writing> icons started to show up.
Tried deleting and re-adding the module in close proximity to the ISY. Same behavior.
Once added, do ZWave devices update without being in linking mode?
Attached is an article on the Zwave network
Not sure why you're seeing the wrtie updates. What is the model of the zwave device you're trying to install.
What controller and Zwave dongle are you using
ZWAVE network repair.pdf
