How do I log into easy.local after 6.0 update?
I went to the easy.local link and it's asking to sign in. Am I making a new sign in? Or am I re using something from elsewhere?
If that's the eisy-ui login screen (black background), then log in with your portal username (usually your email address) and password.
I have this when I follow the eisy-ui link. I'm not sure how to add my eisy
completely unrelated, I get this when I double click on the image to make it smallerScreenshot 2025-10-19 at 4.06.03 PM.png
all tabs are blank
Yes, that's what I've been using. The new way hasn't worked for me yet.
(Not a comment on the product, I just don't understand what I'm doing clearly)
What happens if you try logging into PG3 the old way, through the IoX menus? And logging into the portal via the link on thw UDI web site?
To make sure I'm doing it right, I went to Plugins/Launch PG3 in the old IoX Launcher
The pic is what I got after being warned the site may be dangerous.
I'm not sure what the link is on the UDI site but I just use my.isy.io and that works fine
Well that doesn't look right. Are the plugins themselves working? You could try rebooting your controller and see if that changes anything.
To be fair I don't know if I have any plugins. When would I have installed them and for what devices?
Well I'm only trying to get you to compare how things work now vs before the upgrade. Plugins are extensions that you install to add new functionality for things like Hue l8ghts, Elk alarm systems, etc. Sounds like you haven't installed any yet. So maybe you have an issue that was there before the update. You might need to open a ticket to figure out what's up with your controller.
I'll open a ticket and see what Michel says about that error message.
Thank you
