October 31Oct 31 I have now tried upgrading my EISY both from administrative console and from UD Mobile. In both cases, dialogues and notifications tell me that an upgrade is in progress and eventually the system reboots, but when I log back in I am still on loX v.5.8.4. Any suggestions?
October 31Oct 31 It won't reboot by itself, but will pop up a message in admin console, telling you that a reboot is needed. you then need to click on Reboot in the configuration screen. You might need to wait a while (20 minutes or more).
October 31Oct 31 Author Guy, thanks. It logged me out of administrative console and told me to log back in. It never told me specifically to reboot but I assumed it rebooted itself since it logged me out. In any event, I did reboot just now and still no upgrade. I should add that in UD Mobile I received notifications telling me that the upgrade was in progress and later that “Upgrade complete!”
October 31Oct 31 Author The recovery instructions seem to apply to the situation where “your eisy does not come back online after 2 hours”. My system is up and running just fine, but simply hasn’t upgraded.I will submit a support ticket before going through that procedure, but was just hoping someone had a quick answer.
October 31Oct 31 I know, but it still attempts the upgrade. But opening a ticket is just as valid. Let us know how it works out.
October 31Oct 31 @Ed Sybesma After the upgrade did you clear your java cache and download the current version of the IoX Launcher from here:https://isy.universal-devices.com/start.jnlp
October 31Oct 31 Author Hi Techman,after the upgrade attempt, Java required me to upgrade Java in order to log into administrative console again, and I did so. I had not previously downloaded and updated version of the IoX launcher, but have done so now. Unfortunately, that didn't change anything.
October 31Oct 31 @Ed Sybesma Run this link which will show the details of your eisy firmware and post a copy of the .TXT filehttps://eisy.local:8443/WEB/sysconfig.txt
October 31Oct 31 Author That link gives me The error message: This site can’t be reachedCheck if there is a typo in eisy.local.If spelling is correct, try running Windows Network Diagnostics.DNS_PROBE_FINISHED_NXDOMAIN
October 31Oct 31 Are you able to access the admin console, if so click on HELP | ABOUTWhat does it show for firmware and UI
October 31Oct 31 Author Yes, that's how I know the upgrade didn't work:Firmware loX v.5.8.4 (2024-06-27-11:35:44)Ul loX v.5.8.4 (2024-06-27-11:35:44)FYI, I submitted a ticket and Michael is having me reflash my EISY. I just hope that goes smoothly!
November 21Nov 21 Hi. I have exactly the same problem as above. The eisy is at version 5.84 and refuses to update despite going through the process multiple times. I do loose connectivity with the admin console during the process but after reconnecting it is still at 5.84. What process was followed to resolve the problem?Thanks,
November 21Nov 21 Author I submitted a support ticket in order to get access to files and instructions for "re-flashing" the EISY.
