DysonFan v5.0.0 beta released
I have just posted a new version of the DysonPureCool plugin to the beta store, version 5.0.0.
It has many changes will should improve interoperability with eisy-ui and UDM. I would suggest installing it in a separated slot from your Production version (you probably will not be able to run them both at once) since there significant profile changes which will require most IoX programs to be rewritten. Since the plugin is now names "DysonFan", it will not try to install over the same slot anyway, without deleting the old one first.
Once again, I only own a Dyson TP07 series PureCool so the plugin is only thoroughly tested with that fan. There are some minor code changes affecting all models, but the PH02 and TP02 should still operate as previously. Please test these and if you have any issues, PM your logs (in "DEBUG" mode) and I will do my best to accommodate.
