November 26, 2025Nov 26 @Jimbo.Automates I added two new sensors to one thermostat and removed one from that thermostat and added it to another thermostat. The two new ones are under the correct thermostat and the old is also still under that thermostat as well and did not get changed to the other thermostat. I restarted the plugin and did a discover but that only added the two new ones. Any ideas? Thank you.
Saturday at 05:25 PM3 days That's not surprising, I'll have to force an update for this but not sure if PG interface supports this, but I'll check. Can you ungroup them both, then group and see if they go under the proper one? Also, check the PG3 UI nodes page to see if it shows the proper parent. If there are issues I can try to get a fix in the beta.
Saturday at 07:17 PM3 days Author 1 hour ago, Jimbo.Automates said:That's not surprising, I'll have to force an update for this but not sure if PG interface supports this, but I'll check. Can you ungroup them both, then group and see if they go under the proper one? Also, check the PG3 UI nodes page to see if it shows the proper parent. If there are issues I can try to get a fix in the beta.I had this issue as well before it went down and even when I wrote my own plugin the problem persisted. My plugin is not a polished as @Jimbo.Automates but for now it is getting the job done.
Saturday at 07:39 PM3 days Ok, I'll look at it when I return from vacation at the end of the month. May have to delete and re-add but maybe a force update will do it.
