Node Server not starting "correctly" after eISY boot
@Goose66 I noticed once before and thought it might be a fluke, but I had a power failure today and a couple hours later was testing on the Schlage issues. It didn't make sense results I was getting until I realized the DSC plugin was not updating fields. Restarted it and status started showing. With a little more work, it appears same happens to Schlage after a reboot.
It did not do this in past so I'm guessing the latest PG3X update may have conflict with plugin. Can anyone else confirm issues after a reboot that has latest update installed.
Edited by hart2hart
I don't think this issues is isolated to Schlage plugin.
I have been experiencing the same issue with 3 plugins. UD has been working to try and find the cause.
I strongly urge you to open a support ticket with UD. If possible, include the plugin log package from the same day you had the issue, before and after the restart.
Thanks. I will submit ticket. I’ve seen it on Schlage and envisalink-DSc and think I may have seen it couple other places dive the pg3x update a week ago.
