Dusk/Dawn Sensors. Is there a max?
Hello
I have ten 2420M motion sensors in my home serving 10 different rooms.
All of them work when it comes to motion and all of them report their status, as On/OFF, in "Current State" on the ISY-99i's Main device list table.
However
Only 5 of them report the "Current State" as either On/Off for Dusk/Dawn. The remaining 5 report nothing (blank) and I can't use this status for programming.
Is the ISY-99i limited to only being able to read 5 Dusk/Dawn sensors?
btw the 5 that don't work are all located near an access point and near other sensors that work. All sensors have both jumpers 3 and 5 set to on.
If the motion sensors are the newer type with the trim pot adjustments then check the dusk/dawn settings thru the ISY. If the dusk/dawn is set for 0 the motion sensor will never send a d/d On.
Tim
Hi
All of the Motion Sensors are Rev 2.0
Thru the ISY all of the Dusk/Dawn settings, including the one that are reporting an ON/OFF, are set to 102.
