Monday at 09:21 PM5 days The PG3 is stuck at ELK Connection started... Config info will update when complete.
Tuesday at 02:30 AM5 days 5 hours ago, hbdude said:The PG3 is stuck at ELK Connection started... Config info will update when complete.You need to add the non secure port to the IP address, as per the instructions:"Set host to the host or ip address and port, e.g. 192.168.1.15:2101"The non secure port is 2101. In addition make sure Elk M1XEP is not set for "secure port".Remember, only one connection can be made to Elk at a time. Therefore, you can not be in ElkRP2 while trying to connect with the plugin.
Tuesday at 04:35 PM4 days Author Thanks for your replyMy secure port is set to 2601. Should it be blank?
Tuesday at 06:25 PM4 days 1 hour ago, hbdude said:Thanks for your replyMy secure port is set to 2601. Should it be blank?You must use non secure port as shown in the plugin instructions. The plugin will not work with the secure port.You also need to follow the example in the instructions for adding the port at the end of the IP address, :2101.
