Did eisy software update
Shot in dark. Did you just upgrade to 6.0 branch of FW? If so, it uses the portal credentials for authentication vs the local.
I have the portal identification but i get access denied message
2 hours ago, Control74 said:
Updated eisy firmware and can no longer login
Will you please provide more information?
  • What firmware did you upgrade to? (give actual number, if known)
  • Open this page in a browser: https://eisy.local:8443/WEB/sysconfig.txt (Click "Advanced" and "Proceed..." if you get any warnings)
  • What versions do you see for:
    • udx
    • iox
    • eisyui
  • How are you trying to log in?
    • eisy-ui
    • admin console
If you're trying to log into admin console with the IoX Launcher you'll need to manually add the local credentials address. Try adding "https://eisy.local:8443/desc" then using your previous local user/pass combo to login. If your IoX window shows the local IP without a port then you will need to use the email and password that it used to log into the UD Portal site (https://my.isy.io).
If you're having issues with the web UI be sure to perform a page refresh and/or close the browser then open it again and hit refresh (or even hard refresh - varies depending on computer OS and browser).
