December 23, 2025Dec 23 Two fixes, one which only effects ratgdo garage node hopefully preventing hanging ; two fixing Toggle and onDelay so they send only DON and DOF.Feel free to test and let me know if everything is acting as expected.VERSION = "3.1.26""""3.1.26DONE add timeout to ratgdo requests and sse client to prevent hangingDONE chg DFOF to DOF for Toggle & onDelay3.1.25DONE add onOnly deviceDONE update generic project filesDONE Controller comments, refactor checkParamsDONE change hints for temperature devicesDONE testing added3.1.24DONE configuration based optional overide initial default3.1.23DONE add onDelay, offDelay, toggle switch, update documentationDONE magic number scrub3.1.22DONE generic/dimmer static/dynamic behaviour Edited December 24, 2025Dec 24 by sjenkins ooops 3.1.26
December 25, 2025Dec 25 I guess triggering device changes from UD Mobile is indistinguishable from doing the same thing from Admin Console, right? It would have been nice if turning a virtual switch on or off from UD Mobile could generate Control events as well as Status change events, just like a physical switch. Wishful thinking?
December 25, 2025Dec 25 Author 3 hours ago, Guy Lavoie said:I guess triggering device changes from UD Mobile is indistinguishable from doing the same thing from Admin Console, right? It would have been nice if turning a virtual switch on or off from UD Mobile could generate Control events as well as Status change events, just like a physical switch. Wishful thinking?@Guy Lavoie ,You have mentioned this before & didn't understand so I think my answer was incorrect.I am able to trigger scenes with a virtual switch both from UD Mobile and the the Admin Console. I am also able to trigger a program using a virtual switch from the AC and have programs turn a light ON or OFF using control.I just verified both again to make sure there were no changes.For example:test dimmer ON - [ID 0068][Parent 01B1] If 'Virtual Device Controller20 / Test Dimmer' is switched On Then Set 'Living / Living Fireplace Lt' On Seeking to understand here ; can you explain more what you are trying to & what isn't working?
December 25, 2025Dec 25 9 hours ago, sjenkins said:Seeking to understand here ; can you explain more what you are trying to & what isn't working?What's not working is...my brain! Hehe, I just retested this and yes, it does generate control events. I've only been into the eisy for just over a year, so I'm still learning. That excuse will thus be expiring sooner than later 😀. I think that what threw me off was that initially I was testing it from admin console, before I got more into UD Mobile, where it really becomes more useful. It would be handy if UD Mobile allowed you to optionally display a switch as two little on/off buttons instead of default toggle, without needing to go into the switch's detailed menu. So Virtual just keeps getting better. Even more when you understand how it works! 😄
