Unable to authorize ring plugin
Hi all,
I just found my ring devices not responding as programmed with my Polisy, so logged into PG3 to investigate. I found the ring plugin at 1 rev behind (1.2.6) and a notification stating I needed to initiate authorization. I re-installed the plugin to get to current (1.2.7) but I am finding that the "Authorize" button does nothing.
I did go into the log and found an error that I do not understand, and I am not sure if this has anything to do with the authorization issue. The error is as follows:
udi_interface.interface ERROR    interface:_handleInput: _parseInput: node address 23320864_lt does not exist. {'address': '23320864_lt', 'cmd': 'DON', 'query': {}}
@bmercier Is there any known issue with re-authorizing the ring plugin?
Thanks for any help!
