Status Updating Delays
Since upgrading to version UD 1.4.14, it's taking upwards of 20 seconds for device statuses and programs to update (prior it was 3 or 4 seconds). I've noticed this on multiple devices. All running 1.4.14 and all statuses hanging since upgrade. I've tried rebooting IoX (V6.0.3) and still get the same results. Note: I have 2 IoX locations and this is occurring in each location whether on WIFI or not.
Is anyone else experiencing these delays?
Not normal, but cannot test on 6.0.3 as the current patch is 6.0.4 which has bug fixes. Also UDM 1.4.15 is awaiting apple's review so should be released soon, so also worth a try after upgrading to 6.0.4.
If issue persists after upgrade try to disable each of the controllers to check if it is isolated to one (Home Tab Menu > Controller's Settings > System Settings), cancel requests to synchronize. The reason is one controller may be publishing too many status updates causing UDM to appear slow for both controllers.
Thanks Javi. I upgraded to 6.0.4 and got the same result (a little worse; more than 30 seconds). I disabled each of the controllers to isolate and got the same result on each. Hopefully UDM 1.4.15 addresses the issue.
