2.5 RC1: timed event didn't fire
The following didn't run (this was one I forgot to remove the 'for 2 minutes' from, but I think it still should have worked):
On Mon, Tue, Wed, Thu, Fri
From Sunset - 25 minutes
For 2 minutes
Set 'CBR/SouthWall - Tracks' On
In the summary screen it shows that it ran at 4:12 pm, so it may just be some communications issue rather than something with scheduling.
I mentioned it because the previous problem with timers not running also updated the 'last run time' and didn't run it.
I'll report if it doesn't run it again. Other programs I had removed the '2 minutes' hack on DID run OK FWIW.
