November 29, 200717 yr The following didn't run (this was one I forgot to remove the 'for 2 minutes' from, but I think it still should have worked): If On Mon, Tue, Wed, Thu, Fri From Sunset - 25 minutes For 2 minutes Then Set 'CBR/SouthWall - Tracks' On Else - No Actions - (To add one, press 'Action') In the summary screen it shows that it ran at 4:12 pm, so it may just be some communications issue rather than something with scheduling.
November 29, 200717 yr It is likely a communication problem, because if the summary is updated with a time then the program did run at that time. (i.e. part of running the program is setting the last run time)
November 30, 200717 yr Author I mentioned it because the previous problem with timers not running also updated the 'last run time' and didn't run it. I'll report if it doesn't run it again. Other programs I had removed the '2 minutes' hack on DID run OK FWIW.
