15 hours ago15 hr Is there any way to use the old login for eisy admin console? I am getting tired of having to put in my portal email and (very long random) password. The eisy is behind a router firewall and is inaccessible from the Internet.I see that in order to use PG3 login, i use the old eisy (ISY) password and uid.
14 hours ago14 hr It should work if your URL in IoX finder has the port number (8443). If your URL doesn't have it, click on "Add" and enter a URL with IP address and port number, like this (ex: IP address 192.168.0.123)https://192.168.0.123:8443/descThen try using that to access your eisy. It should prompt you for your IoX login and password.
12 hours ago12 hr You can also use the following, just add the 2nd line and then save it. Edited 12 hours ago12 hr by Techman
12 hours ago12 hr 35 minutes ago, Techman said:You can also use the following, just add the 2nd line and then save it.Thanks. Worked for polisy also with"https://polisy.local:8443/desc Edited 12 hours ago12 hr by larryllix
