Bathroom Timer Program
I have a timer for our bathroom and I have been receiving complaints from the occupants of the lights suddenly turning off, so I figure to add a 1 minutes warning. Here is my code:
Bathroom Light Timer
       Status  'Bathroom Light' is On
       Wait  30 minutes
       Set 'Bathroom Light' Off
       Set 'Bathroom Light' On
       Wait  1 minute
First, is this an efficient program and second how would I go about "re-activating" the timer to start the 30 minute count down again?
Ok, activating the switch to the on position restarts the timer.
Hello Mark,
In your program below, when you set the bathroom light to off your "if" condition will become false (i.e the bathroom light status is no longer "on"). The remainder of your then statements may not execute.
Try using a control condition for your if statement instead (i.e. If bathroom light is switched on). This should prevent the statements in your "then" loop from re-triggering the program.
       Wait  30 minutes
       Wait  1 minute
Mike,
I see what you mean, so I decided to change the criteria in my If statement, this seems, to work:
       Control 'Bathroom Light' is switched On
       Wait  15 minutes
       Wait  2 minutes
