eisy-ui not installed?
Successfully upgraded my EISY to 6.04 and everything seems to be working, however when I try to use http://eisy.local or https://eisy.local, I get "connection refused".
IOX Finder only displays the usual port 8443 url for the admin console and nothing more.
How can I confirm I have eisy-ui installed, and if needed, install it?
You won't see a link for eisy-ui in IoX finder. Try your eisy's ip address directly, such as:
http://192.168.0.123
Edited by Guy Lavoie
IP address doesn’t work, either. Do I need to enter a port as well?
Update:
Seems my solution resembles this earlier thread .
Thanks to Michel and his prompt response to my ticket, I successfully installed and started eisy-ui by accessing eisy.local via command prompt and following the ssh commands.
